How to calculate the bending angle for pipe with external coating
juancd200914
Petroleum
EC
Please explain - the coating should make no difference to the angle
with very large angles the external coating is usually cracked in the ASME B31.8 there is a table that indicates the degrees / PD but does not specify if it is for coated pipe
Dear juancd200914
Normally unpainted pipes are bent as there could be a PWHT after hot bending.
If a coated pipe is bent, check the coating after bending. If it is intact, then no issues, else you have to go for a localised repair of the coating.
Regards.
DHURJATI SEN
juancd200914,
I think you really mean the "bending radius" and not the "bending angle"?
A "hard" coating, inside or outside, the pipe may have problems with any bending radius.
A "soft" (or elastic) coating, inside or outside the pipe will tend not to have problems with a bending radius.
If you can bend your pipe without damage to the coating then the angle of the bend will not matter.
Sometimes its possible to do all the right things and still get bad results
juan,
It's always best to define what you mean and references so I assume you mean table 841.2.3-1.
This only relates to the steel pipe and is based, I believe, on a maximum strain in the outer edge of the pipe of 2%.
Now whether your coating can withstand a strain of 2% no one would know. some coating e.g. FBE, usually can. Some harder more brittle epoxy or glass type coatings might not.
Despite that table, most pipeline designs I see use 40D as a standard cold bend radius for all diameters and this has become an effective industry standard. So for smaller pipes it is less strain, but larger pipes it's getting close to the 2% limit.
Does that help?
