M
mdristy
Guest
Is there any way to modify or assign the densities of the parts that make up an assembly from within the assembly model? e.g. without having to open each part and assign the density from within each part individually?
I remember many years ago you could do this, at least if a density hadn't been already assigned to the parts.
I am currently using Pro/E WF 4.0 & also CREO 2.0
Thanks.
Thanks.
