How to anchor a revision table 2
tabby1
I have some difficulties to anchor the revision table in the right top corner of a drawing sheet once the drawing views already placed. It always shown in the left bottom corner and I do not know how to move it. It seems that no click or right click on the table is available.
Can you help me. Thanks
Click where the "plus-sign-with-arrows" is on the revision table to get the property manager to show up. Then, you can select the proper table position in the property manager.
RMB on the drawing (not a view) and enter the Edit Sheet Format mode, then RMB the intersection to be used for the anchor point, select Set as anchor and choose the anchor type.
Apart from what CBL suggested, you can also right click on the revision table, etc. in the feature manger under sheet format, select anchor and then select a intersection or any other point to set as anchor for that particular type.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
 http://files.engineering.com/getfile.aspx?folder=e0f58602-1f4c-4fda-a925-8285bd18fc3e&file=Anchor.PNG
