1
- #1
Hi All
Long time reader, first time poster! I'm hoping I can dip into this huge knowledge base for some answers to a problem we cant solve.
A bit of background first for context;
I'm a design engineer for a valve manufacturer. We are currently applying for the API monogram for our range of butterfly, ball, and swing check valves. All our current products were designed way back before I was even thought of and they have not changed much since, a lot of key staff have come and gone and various corporate groups have owned us along the way. This has left our design data in a bit of a state to put it mildly. My job at the minute is to re-write all the design reports and calculations for the aforementioned valves in preparation for the audit in a couple of weeks.
So to my problem. I am having trouble analysing the disc for swing check valves during back flow. For smaller sizes, the disc is (more or less) flat and treating them as a flat circular simply supported plate, as per Roark, is fine. However, from 6" to 10" the disc is dished/ellipsoidal in shape and analysing as a flat plate does not work. We know they do work, we've been making them for decades! I looked at treating it as a pressure vessel head, but this gave an unusually low stress I don't trust (it was 60% lower than the quick FEA I did). I think it's due to the fact that this assumes the outer circumference to be fixed (as in welded the the vessel body) and not simply supported on the seat as is the case in a valve. We cannot find any legacy data on our servers and I've searched the internet with no luck.
Please can anybody help with this analysis of what is essentially a dished/ellipsoidal circular plate, simply supported around its outer edge, with a pressure/UDL on the convex side, class 150?
Thanks in advance for your time, he says hopefully...
