how to access the instance's vertices of a wire by python
laoyanwei
New member
CN
I use the abaqus python to create a wire in Interaction Module, sth like this:
mdb.models['Model-1'].rootAssembly.WirePolyLine(mergeWire=OFF, meshable=OFF, points=((mdb.models['Model-1'].rootAssembly.instances['I'].vertices[10], mdb.models['Model-1'].rootAssembly.instances['I'].vertices[11]), ))
mdb.models['Model-1'].rootAssembly.Set(edges= mdb.models['Model-1'].rootAssembly.edges.getSequenceFromMask(('[#1 ]', ), ) , name='Wire-1-Set-1')
then a feature + an edge is created correctly.
And the two vertices for creating this wire are instance's vertices. But when I use the python function Edge.getVertices, it only returns rootAssembly's vertices ID instead of Instance's vertices.
So how to get the instance's vertices.
Instances are not created in the Interaction module. Instances are created in the Assembly module from Parts.
You are creating just features in the assembly.
