Apr 5, 2004 #1 Cthornton Civil/Environmental Joined Mar 18, 2004 Messages 9 Location US I came across the following in a specification: "...positive internal pressure of + or - 10 inches wg" 1. What is wg? 2. How can I measure it? 3. Can it be correleated to psi or inches Hg? thanks in advance chad
Apr 5, 2004 1 #2 GregLocock Automotive Joined Apr 10, 2001 Messages 23,893 Location Orbiting a small yellow star Probably water gauge, which you might use to measure the pressure created by a fan, for example. In which case divide by 13.6 to get inches of mercury. Cheers Greg Locock Upvote 0 Downvote
Apr 8, 2004 1 #3 fredt Mechanical Joined Sep 21, 2003 Messages 85 Location AU I would confirm Greg Locock's advice that it is inches water gauge IE 10"WG is the pressure that will support a column of water 10 inches high. If you are in ISO land multiply by 0.248 to get kPa (kilopascals). IE 10"WG equals 2.48kPa. Upvote 0 Downvote
