red123
Automotive
- Sep 3, 2005
- 4
I have been working for many years on a true rotary engine project that will use injected water at 1500-psi and 263-F to cool super-hot combustion gas down to an intermediate temperature level of 1400-F. (combustion at all operating speeds is stoicheometric, approaching 4000-F). This commingled combustion gas and steam then goes through isentropic expansion until it exhausts from the cylinder at only 19.6-psi and 312-F. The engine is a 440 cubic inch displacement single cycle machine, that produces power on every revolution due to an innovative and proprietary mechanism that constantly exhausts the products of combustion from each previous cycle without interferring with the power being developed by the current cycle. The machine has a 40 inch long circular cylinder; 10 linier inches is dedicated to the combustion process and the remaining cylinder length is dedicated to expansion of the commingled gas/steam volume.
Although earlier calculations indicate that this process will have enough time to be completed, thereby cooling the circular cylinder metallurgy to a level that can be managed, I would like additional opinions about whether water sprayed through multiple ports directly into the combustion chamber immediately after combustion is completed, will have enough time to fully vaporize and absorb the necessary heat from the combustion gas volume.
Since developing a prototype engine is a major financial effort for which I must be fully responsible, I cannot proceed further until I am totally convinced that the cylinder cooling process is a sound means for protecting the metallurgy. I would like the help of engineers with expertise in the area of direct contact heat tranfer to express their candid opinion, citing their actual experience with similar activities, or reference materials to support their (agreement) that the process is sound, or their (dissagreement) that the process is not sound.
Design criteria: The engine operates at 1800-rpm electronically governed to plus/minus 1-rpm at any operating speed.
Fuel flow (87-octane gasoline)is 46.55/lb/hr. Combustion gas flow equals .2161/lb/sec., or (.0072/lb/rpm). Injected water vapour flow is .1258/lb/sec., or (.0052/lb/rpm).
Combustion pressure at the time of water injection is approx. 640-psi.
