How does viscosity effect HPSHr? 2
keaand
Chemical
GB
If the NPSHr of a pump is normally measured using water, how does the actual viscosity of the pumped fluid effect the NPSHr? I would have thought that increased fluid velocity would have increased the pressure drop between the pump suction and impellar and as such the NPSHr of a pump would increase with increasing viscosity. I can't find any details of viscosity correction for NPSHr. Anyone able to confirm if NPSHr should be corrected for viscosity.
Generally NPSH values given in the performance curve sheets are measured values which correspond to a loss of discharge head of 3%.
The total heads and the performance characteristic shown on these curves, apply to media with a density of 1 kg/dm3 and a kinematic viscosity up to 20 mm2/s. If the density is other than 1 the friction must be multiplied by rho.
You can learn a little bit more of viscosity correction on pumps here:
Also, the following link has an excel datasheet that uses the Hydraulic Institute method to predict how a centrifugal pump will perform with higher viscosity fluids:
Hope you find it useful,
EB
i have the performance correction chart, if you need it i could mail it to you!. Just let me know
EB
