this is my first time posting in this great forum and I think I might have an interesting question.
I am performing some EMT simulations in order to study the effects of energizing a transformer. I have several transformers running in an islanded network and I get the sympathetic inrush phenomenon. Due to that the inrush magnetization current lasts longer and so does the voltage dip at a certain terminal.
At that terminal a positive-sequence voltage relay is installed and should issue a tripping signal 50 msec after the voltage goes below 0.84 p.u. It does go below 0.84 pu if I take the average. But due to the harmonics caused by inrush magnetization current this positive-sequence voltage is really jagged. It may jump from 0.7 pu to 1 pu several times during one cycle.
So my question is: does the relay filter the average value out of this jagged signal and will issue a trip or will it just follow the jagged signal and get resetted every time the voltage crosses 0.84 pu?
Thank you in advance.
stason
stason
