May 18, 2015 #1 damakuno Mechanical Joined May 18, 2015 Messages 3 Location SG For example, I want duplicates of a Hole across a surface along the XC axis but none along the YC axis, how will I be able to do it?
May 18, 2015 #2 mathisudar2007 Automotive Joined Aug 1, 2012 Messages 100 Location IN Hello, First create a smart point and pattern it. Second step is,create the hole using the patterned point / smart point. Thanks, Mathi K Upvote 0 Downvote
May 18, 2015 Thread starter #3 damakuno Mechanical Joined May 18, 2015 Messages 3 Location SG so pattern the point first, then create the holes using the points? Though my real question is, how do you pattern only along one axis? It seems to force me to pattern YC even though I really just want to pattern XC Upvote 0 Downvote
May 18, 2015 #4 phillpd Mechanical Joined Oct 19, 2006 Messages 780 Location GB You should be able to just set YC to 1 NX 9.0.3.4 NX 10 (Testing) Windows 7 64 (Windows 8.1 Tablet) Upvote 0 Downvote
May 18, 2015 Thread starter #5 damakuno Mechanical Joined May 18, 2015 Messages 3 Location SG Okay, thanks for the help Upvote 0 Downvote
May 18, 2015 #6 JohnRBaker Mechanical Joined Jun 1, 2006 Messages 38,022 Location US What version of NX are you using? If it's NX 8.0 or newer, when creating a Pattern, simply you only ONE axis (toggle the other one OFF). John R. Baker, P.E. Product 'Evangelist' Product Engineering Software Siemens PLM Software Inc. Digital Factory Cypress, CA Siemens PLM: UG/NX Museum: To an Engineer, the glass is twice as big as it needs to be. Upvote 0 Downvote
