How do you get the Document's Instance Number? 1
Ruky
Aerospace
CA
I have the following code below. My intent is to get all the instance partnumbers from all the documents in my activedocument.
I expect that the variable "nam" below will give me XXXXXXX.1 ,XXXXXXX.2, ...,XXXXXX.n
but the variable just returns XXXXXXXX.CATPART, XXXXXXXX.CATPART,....,XXXXXXXX.CATPART with no instance numbering.
I think nam = docus.Item(k).Name is the wrong approach but I do not know any other approach.
Any suggestions/solutions?
Sub CATMain()
Dim docus As Documents: Set docus = CATIA.Documents
Dim r As Integer
Dim i As Integer: i = docus.Count
For k = 1 To i
Dim nam As String: nam = docus.Item(k).Name
MsgBox nam
Next
End Sub
Hi ferdo,
That approach works, but if I want to use catvba all the way, is there another way of getting the instance numbers?
Thanks for the quick response
I've posted similiar code few days ago:
This code is listing all partnumbers and partnames according to their's positions in document's tree
Code:
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
  If InStr(CATIA.ActiveDocument.Name, ".CATProduct") < 1 Then
     MsgBox "Active CATIA Document is not a Product. Open a Product file and run this script again.", , msgboxtext
     Exit Sub
   End If
   Call ListingNames(productDocument1.Product)
End Sub
Sub ListingNames(current_prod)
If current_prod.Products.Count > 0 Then
For i = 1 To current_prod.Products.Count
Call ListingNames(current_prod.Products.Item(i))
Next
Else
MsgBox current_prod.Name
End If
End Sub
If You are interested in Macros in Catia (Catscripts, Catvba) feel free to send me a message. I will wrote specified macros for free and post it on eng-tips forum
Code:
Sub CATMain()
REM Works in an active CATProduct
Dim productDocument1 As Document
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
Dim HSOSynchronizedFilter(0)
Dim sel
Dim Status
Set sel = CATIA.ActiveDocument.Selection
HSOSynchronizedFilter(0) = "SetCATIADotHSOSynchronizedToFalse"
selection1.Search "(CATAsmSearch.Part + CATAsmSearch.Product),all"
For i = 1 to selection1.Count
SelectionList = SelectionList & chr(10) & selection1.Item(i).Value.Name
Next
MsgBox "Selection is " & SelectionList
selection1.Clear
HSOSynchronizedFilter(0) = "SetCATIADotHSOSynchronizedToTrue"
End Sub
Fernando
Hi ferdo,
That works! Although I've gotten a bit greedy and tried if I can acquire the parent product of each selected item the macro loops through. I tried doing this:
Prnt = selection1.item(i).value.parent.name. It worked well for the first item on the selection. But the next iteration gave "products" for Prnt. Does that mean that the loop is also looking at the grandparents of the item (i)?
If this is the case, how do I tell the compiler to just look at the immediate parent of item (i)?
Thanks!
Code:
Dim Listed
Sub CATMain()
     Exit Sub
   End If
ProductName=""
   Call ListingNames(productDocument1.Product,ProductName)
Msgbox Listed
End Sub
Sub ListingNames(current_prod,pathname)
pathname2 = pathname &"\"& current_prod.name
Call ListingNames(current_prod.Products.Item(i),pathname2)
Next
Else
'MsgBox pathname &"\" & current_prod.Name
Listed = Listed & chr(10) & pathname &"\" & current_prod.Name
End If
End Sub
This one would works at every level of assembly (I Reported my post below, there is small mistake, that I've noticed after submitting)
LukaszSz. Poland, Warsaw University of Technology, Faculty of Power and Aeronautical Engineering : MEchanical Engineering. BsC - 2013
Yes! it works!!!....using .Parent twice is something very foreign to me. I didn't know that was possible.
Thanks!
I wrote small function:
Code:
Function AssemblyLevel(oProduct)
If oProduct.Parent.Parent.Name="CNEXT" Then
AssemblyLevel=1
Else
AssemblyLevel=AssemblyLevel(oProduct.Parent.Parent)+1
End If
End Function
and testing macro:
Code:
Dim Listed
Sub CATMain()
     Exit Sub
   End If
ProductName=""
Msgbox Listed
End Sub
Next
Else
Listed = Listed & chr(10)&"Assembly level:"&AssemblyLevel(current_prod) &" path: " &pathname &"\" & current_prod.Name
End If
End Sub
AssemblyLevel=1
Else
End If
End Function
Nice solutions, a star from me.
But if you are using this script on a CATProduct coming from a PDM system (like VPM for example), you have to modify because is giving an error due to the first condition:
Exit Sub
End If
Fernando
