M
mandrews67
Guest
I need to create a volute for a project. I assume you create a pattern of points with an equation then create a curve through the points. If so, what is the equation? Once curve is created do you use a variable section sweep? or is there another option? A model of a volute would help tremendously so I could see how it was created.
