How do you copy a part and it's associated drawing...assembl
  • Thread starter Thread starter tjones
  • Start date Start date
T
tjones
Guest
Hello: I hope someone can help me, I am learning pro-e
on a student edition and I can't figure out how to copy
a part or sheetmetal model and it's associated drawing
to new files for modifiction. also I can copy an assembly
and all it's parts to another copy, but how do you get
the draft of the assembly model and the sub parts drawing
to copy
Note: I used help and it said to: create new, uncheck default
template, and supply a model for the template and check copy associated drawings, but I get a message that says:
Model of this class is not allowed to copy from
Is this a function of student edition?
Tim
To copy a part & assoc drawings:
1. Open the drawing file (this will bring all associated files into session).
2. Open the part (which should now be in session) and execute file: rename--IMPORTANT: Select the option in session only and type in new file name.
3. Change window back to the drawing.
4. Rename the drawing to a new name (use in session option)
5. Once renamed, save the drawing.
You now have a completely new linked part & drawing of a different name.
Open files in this order:
Drawing
Assembly(s) - if any
Part(s)
Rename in the reverse order, i.e:
Part(s)
Assembly(s)
Drawing
Save the drawing and all renamed children will be saved also..
PS Don't forget to save the originals in a different directory...
thank you all for replying
Tim
I have found that you want to go into common space. Copy both and give new name. They will be linked together.
This is done provided you are connected to intra-link.
There is also an option (2001 & i2) in the config.pro, as well, that will make a copy of both the drawing, assembly, and part.
