how do i use a dialog to find just a path (not a file) ?
IanMcA
Computer
GB
I'd like to use a dialog box to allow the user to find the path to a set of folders but what i've seen so far seems to only work when you select a file (otherwise the 'open' or 'save' button remains greyed out.
Is there any way to use a dialog to allow the user to select just the path without having to select a file?
In this instance i'm using Excel 97 SR-2
Thanks in Advance
Ian
Code:
'32-bit API declarations
Declare Function SHGetPathFromIDList Lib "shell32.dll" _
  Alias "SHGetPathFromIDListA" (ByVal pidl As Long, ByVal pszPath As String) As Long
Declare Function SHBrowseForFolder Lib "shell32.dll" _
Alias "SHBrowseForFolderA" (lpBrowseInfo As BROWSEINFO) As Long
Public Type BROWSEINFO
    hOwner As Long
    pidlRoot As Long
    pszDisplayName As String
    lpszTitle As String
    ulFlags As Long
    lpfn As Long
    lParam As Long
    iImage As Long
End Type
public sub DoSomething()
    'Prompt user to select folder
    Dim lFolder As String
    lFolder = GetDirectory("Select the folder")
    If (lFolder = "") Then
        Exit Sub
    End If
    MsgBox "You picked: " & lFolder
end sub
Public Function GetDirectory(Optional Msg) As String
    Dim bInfo As BROWSEINFO
    Dim path As String
    Dim r As Long, x As Long, pos As Long
'   Root folder = Desktop
    bInfo.pidlRoot = 0&
'   Title in the dialog
    If IsMissing(Msg) Then
        bInfo.lpszTitle = "Select a folder."
    Else
        bInfo.lpszTitle = Msg
    End If
'   Type of directory to return
    bInfo.ulFlags = &H1
'   Display the dialog
    x = SHBrowseForFolder(bInfo)
'   Parse the result
    path = Space$(512)
    r = SHGetPathFromIDList(ByVal x, ByVal path)
    If r Then
        pos = InStr(path, Chr$(0))
        GetDirectory = Left(path, pos - 1)
    Else
        GetDirectory = ""
    End If
End Function
