bikemaniac
Materials
I have some new, unused tires which recently went out of production.
Because they are so damn good I want to store them so that I can use them in future (assume I want to store them for 10-20 years).
The problem with rubber seems to be the fact that the softening agent evaporates with time and makes the tire more hard and brittle. So how can I prevent that from happening?
So far I have heard about the following solutions:
1. Put each tire in a polyethylene plastic bag and weld it so it becomes air tight. Personally I know that polyethylene is not 100% air tight itself as it lets air diffuse through the material very slowly with time. The reason for this solution is to stop the evaporation of
softening agent so one gets an over saturated atmosphere within the bag blocking for further evaporation. I don't know, but introducing a vacuum in the bag might accelerate the evaporation and an over pressure might maybe decelerate the evaporation. Any explanations?
2. Put all the tires in a box filled with talcum.
3. Coat every tire with silicone (using a silicone spray) and let them hang from the ceiling fixed at only two points keeping the tire completely circular.
Of course, all rubber should be stored cool, dry and dark (preferably in a basement).
Anyone with hands-on suggestions, experience etc etc??
regards lucas
PS: Suggestions using liquid nitrogen does not apply
regards lucas
