Guys, I'd really like to thankyou ALL for taking time out to help me here, I really mean it. My internet was down so I couldn't respond earlier, my apologies.
I've attached a zip file that contains file Blade Dimple 1, this will show what kind of dimple I'm talking about. Basically the 3D Sketch grid of lines u'll see is where I'd like to put all dimples, excluding edges.
MattBD: I tried your suggestion, but can't figure out how to make a Dimple like cut, it only lets me make a Deboss, plz check out the file attached "Blade Dimple 1" as it shows what kind of dimple I'm talking about.
JMirisola: Unfortunately it will be something we'll try to cut in steel or make electrode. so Texture won't work.
CADGemini: Thanks for your advice and especially for the CAD file, I really didn't know how to do that so I learned. Now may I request one more thing, plz take a look at the file to see that the dimple would be Debossed and not Embossed, using your technique I was able to use Cut command instead of Extrude but couldn't ge the fillet right, check the files I attached.
rollupswx & TheTick: Guys check out the attached file Blade Dimple 1, I tried your suggestion but it doesn't seem to work. If possible may I get the file you sent the screenshot from?
fcsuper: I tried your suggestion and searched for Golfball files that I found on 3D content, I noticed their technique how they made a small flat surface inside a sphere and created 3 dimples then patterned it across the whole sphere, it doesn't work for me since I don't have a perfectly symmetrical surface.
