How do I change loading rate to speed up quasi-static simulation in Abaqus/Explicit?
kevin555582
6
Big Picture:
I am trying to perform a quasi-static, displacement controlled, 3-point bend simulation on a 2D notched beam. My simulation size is about 7100 variables. Ultimately, I am trying to run this simulation using a VUMAT implementing a damage accumulation material model, but for right now I am using the built in Elastic model while I figure out how to manipulate loading rate. I want to run this model for at least 100 cycles which will be done using steps. I am trying to get the simulation to run in a reasonable amount of time so that I can get information quickly. I have been able to use Mass Scaling to speed up the model, which seems to work, but does distort my results. The only information I want from the simulation is reaction force and displacement, this is because I want to calculate stiffness of the structure (i.e. force divided by displacement). A lot of the documentation online talking about doing Quasi-Static simulations using Abaqus Explicit says that the two ways of speeding up the simulation are mass scaling and controlling loading rate.
Problem:
I want to compare the results using the two methods and see if using a faster loading rate will help with the distortion of my results. I have tried to figure out how to control loading rate but my results are not making sense. I have stepped back from my simulation and am working with a 2D, one by one, square plate while I try to figure out how to manipulate loading rate. Basically, my question is, how do I control loading rate using Abaqus Explicit?
What I have tried:
Under the amplitude keyword there are 4 numbers in a row separated by commas. I have tried adjusting the third number both greater than 1 and less than 1. From what I understand in both the Abaqus documentation and what I have read on line these numbers come in pairs such that the amplitude follows this: time_0, amplitude_0, time_1, amplitude_1, time_2, amplitude_2. I have been using this such that: time_0, amplitude_0, time_1, amplitude_1 where 0 represents the beginning of the step and 1 represents the end of the step. Therefore, I have manipulated the number representing time_1.
From what I can understand it seems like reducing this number to a value less than 1 would increase the rate at which loading is applied and therefore reduce the time the simulation runs. I say this because a rate is an event divided by time. So, if time is decreased the rate should increase.
My results:
Essentially all graphs look the same. In that the data points are not evenly spread out throughout the x-axis. The simulation goes from 0,0 to the second point and then all other points are in a vertical line. It seems like the graphs are converging, but the vertical lines seem odd. Even if I apply this to my notched beam simulation with 7100 variables, it doesn’t speed up at all.
Thank you for the response sdebock.
I have looked through the Abaqus documentation pertaining to the keyword Step and don't see anywhere I can control the runtime. Did you have something specific in mind?
it's under step in CAE
in input file it's under
*dynamic, explicit
, 1 <- step time
you have to specify onto the amplitude tabular in order to get increment and constant strain rate
Thank you for these responses. I have been working with this solution for some time to make sure I didn't have any other questions. It works exactly like I was wanting it too. Thank you both so much for your help, I greatly appreciate it.
