How do I change color of pipes?
  • Thread starter Thread starter mikeheater
  • Start date Start date
M
mikeheater
Guest
Does anyone know hoe to change the color of Pipes in the Creo /Piping Apllication? I cant change colors that way you normally would on a part surface, etcc. Thanks for your help.
Do you use specification driven piping?
I'm not very sure, but I think there ist a configuration file somewhere in the piping directory, which defines the colors.
Regards, DonChunior
Go to the Piping setting, there you will get RGB panel from where you can change the color.
go to Render / Appearance.. then click the drop down next to Clear Appearance, and select Clear All Assembly Appearances... Then you can pick the color you want, click the assembly in the model tree, and it will change the color... that is the only way I've found how to do it for non-spec driven piping.
