Hi dave
Thanks for the formula however I don’t seem to have got the answer I was looking for. I got an engagement length of 1.762 inches, the current fitting that came from the manufacturer only has an engagement length of 0.393 inches. The material being used for the fill valve is brass, material properties taken from
Force = pressure / area
Force = 3625psi / 0.28 inches^2
Force = 12946.42 lbf
Area = Force/yield strength *5 safety factor
Area = 12946.42 lbf / 19600 psi * 5
0Area = 0.660 * 5 = 3.30
Engagement length = Area / Thread Pitch Circumference
Engagement length = 3.30 / 1.872
Engagement length = 1.762”
Contacting the manufacturer is out of the question, I have tried on many occasions about a different issue and when they do finally get back in touch after many attempts they just don’t want to speak to you.
I also found this formula on the internet to calculate pull out force which should help me determine engagement length however I seem to have messed this up as well. I used the engagement length of the original part to try and determine the pull out force.
Lbf = pi * pitch dia * shear strength * length of engagement
Pi = 3.1415
Pitch diameter of M25 x 1.0 thread = 0.596 inches
Shear strength of brass = 34100 psi
Engagement length = 0.393 inches
To work out pull out force:
Lbf = 3.1415 * 0.596 * 34100 * 0.393
Lbf = 25091 lbs
To convert the force required into pressure:
Pressure = force / area
Pressure = 25091 / 0.28 inches^2
Pressure = 89610 psi or 6178.38 Bar.
As you can see I got an answer of over 6000 bar, when the original product is designed to operate at 232 bar this seems a little excessive.
Any ideas where I am going wrong?
Thanks.
