How do I avoid objects joining?
cp3
53
As you can see from the picture, I want my objects to be separate. I drew black lines where I want my objects to stay separate, but instead they kinda joined as one surface? Is there anyway to avoid that? Thanks...
I would be guessing if I thought you have used different features to create each of these 'objects?' If so, then uncheck the 'merge result' box when defining the feature.
Hardie "Crashj" Johnson
SW 2009 SP 2.1
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
Either use the Weldment function, or when extruding the profile, make sure the Merge option is not selected.
You guys are genius. Thanks!!!
I knew about the Merge option so I guess I am a genius too.
