I'm looking to make a circuit that takes a 20-30VDC input and, when that goes high, generates a signal that also goes high, but to a different voltage (2-10VDC). Then after some time of being high, I want it to transition to a 600Hz, 50% duty cycle PWM.
I'm thinking of a monostable 555 and an astable 555 with the outputs diode or'd together. Powered off a linear regulator to drop down the input voltage. This seems a bit inelegant. Any other concepts of how this might get accomplished?
Thanks!
Thanks!
