How can I change in Power Input mode? 1
joseph0517
Automotive
KR
hi everyone
I am using c: in power input mode.
When you move from the tree to the sketch area, c: appears in the status bar.
But when you move to the sketch area in the sub-window of pad, pocket, etc., dim1 and dimension appear.
I hope that c: will continue to appear.
I am having the inconvenience of having to modify the dimensions of the sketch once to eliminate dim1 and dimensions in the status bar.
When you modify the dimensions, you return to c :.
I hope you will only see c: in the status bar without this inconvenience.
Do you know anything about this problem?
please let me know
The option seems to be somewhere.
On some other users' computers, they will only appear as c :.
I am using the v5 r20 version.
Please let me know. Thank you.
i wonder if this is a ENV variable...
Eric N.
