"Of course the cumulative result of the blowby was a noticeable volume of crankcase fumes out the vent (no PCV)"
I had a similar run out engine (in an econoline van) that I simply vented the crankcase vent (disconnecting the road draft tube) to a 1 gallon clorox jug, loosely filled with teflon plumbers tape. The tape attracted the oil mist, which eventually formed droplets settled to the bottom of the jug, to be dispensed back into the sump at next oil check interval. In this way, I was able to extend my oil usage from 1 qt/ 50 miles, to 1 qt/ 150 miles.
