electricpete
- May 4, 2001
- 16,774
Since I am brand new to infrared, please be patient with all my questions.
Here is IR plus visual image:
If visual image is too dark, it may be easier to see here:
This is a 120 vac breaker on output of an inverter.
In lower left hand corner of the picture you see the top of a molded case breaker. It is a 2-pole breaker with right-angle metal busbars bolted on, and lugged cable bolted to the busbar.
1 - Cabinet ambient temperature is 24.6C
2 - The upper left connection (on top of bottom left breaker) is 24.6C
3 - The upper right connection (on top of bottom left breaker) is 44.2C.
(We checked sister unit and items 1 and 2 were identical).
The infrared shows green strip surrounded by two red bands. I believe the lower-temp green strip is caused by the thermal insulating effect of the lug electrical insulating sleeve. Since the terminal stud is not particularly hot, I think the heat comes from the crimp wire-to-lug, rather than bolted connection lug-to terminal.
Emissivity set to 0.95 throughout the image.
What is your opinion?
