blueandwhiteg3
Computer
Can anybody give me a quick primer on hot isostatic pressing?
I have an application where I would like to explore making a part using some kind of a metal-matrix composite / cermet. The objective is extreme hardness (for abrasion resistance) combined with a little more impact tolerance than most ceramics have, and as low a weight as reasonably possible. I do not have extreme tolerances here.
I have located a facility not too far from me that can handle the actual HIP part of the process. It's surprisingly inexpensive on a per-pound basis, particularly given that my part is unlikely to exceed 1 lb. Normal runs are 1680° F to 2180° F, and I believe "normal" pressure is 15 KSI.
I just need to supply them with the material prepared in such a way that it will go through their process without releasing anything (e.g. plastics, binders, aluminum, etc. are all issues.) If I have to go above the normal pressure or temperature, cost goes through the roof as I have to do custom runs.
The problem is that I simply don't know about this field. I would appreciate it if somebody could point me in the right direction on a few points:
1) The part is sheet-like, with a thickness of about 1 mm. Suggestions as to the kinds of materials I should be thinking about for this, given my needs?
2) Once powders are obtained and mixed, how are they formed to be 'ready' for HIP processing? Heat? Chemical binders? Pressure?
