Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
MARPOL said:Hoses
6.2.6.6 / The hoses used for the STS transfer of crude oils or petroleum products should be specially designed and constructed for the product being handled and the purpose for which they are being used. Hoses used should comply with EN1765 (or latest equivalent) with regard to specification for the assemblies and with BS1435 (or latest equivalent) and OCIMF guidelines with regard to their handling, inspection and testing. Hoses should bear the following durable indelible markings:
1 The manufacturer’s name or trademark; 2 Identification of the standard specification for manufacture; 3 Factory test pressure (Note: equal to rated working pressure, maximum working pressure, maximum allowable working pressure); 4 Month and year of manufacture and manufacturer’s serial number; 5 Indication that the hose is electrically continuous or electrically discontinuous, semi-continuous or anti-static; and
6 The type of service for which it is intended e.g. oil or chemical.
