horton sphere/ spherical vessel design for LPG storage 1
chemilocha
Chemical
NG
dear all,
my company got tender for support in engineering services , client gave first job to design spherical / horton sphere for LPG storage , actually we are new for this type of design considerations, i would like to know what are the design considerations need to take while designing spherical vessel? i want information about folowing , if anyone can explain/help me then,its very kind of you poeple,
Factors Affecting the Life Horton sphere
Storage Tank Design Considerations
Instrumentation and Tank Gauges
Piping System Design & Transfer Pump Design
Corrosion and Corrosion Prevention
Tank Foundations & Seismic Considerations
Tank Accessories
Tanker Up-Load and Off-Load Sequence
Tank Inspection, Cleaning, Flushing and Maintenance
Spills and Containment Prevention Considerations
Design of Fire Sprinkler System and Insulation
Safety Considerations
Installation & Commissioning
With respect, your client appears to be an idiot to give the design of such a vessel to a company which has never done it before. That list is basically all the design aspects you need to look at and you're coming onto an internet forum to find it out??
I suggest you subcontract this to a suitably experienced and qualified company and then try and learn some key items from them.
LittleInch is, as always, correct.
It appears that neither you or your client have any experience with Horton spheres or LPG storage.
Most LPG storage tanks are NOT Horton spheres ...... This should tell you something.
MJCronin
Sr. Process Engineer
At least your smart enough to know that you don't know. That is a HUGE mark of intelligence, but you should sub this out to an experienced company and try to learn from them.
StoneCold
Since Horton spheres are design in accordance to ASME pressure vessels according to manufacturers listed on the internet, The National Board may have in their archives information pertaining to some of your inquiries and the ASME pressure vessel code would be an additional resources dealing with the construction of such sphere.
