I am working on a 16" dia by 34" OAL horizontal tank designed to 312 psi. Shell is .250 SA 53B pipe. Heads are 2:1 elip SA414G. The desired mounting is to use 2x2x1/4 angle running parallel to the shell axis such that the tank will be flush to the mounting surface. This is not a saddle design, skirt, lug or legs for that matter. I am wondering what types of calculations I need to perform and where I might find them? Any suggestions would be a big help.
