Horizontal Fiberglass Tank
wfn217
Chemical
Aug 11, 2006
101
What construction code covers horizontal fiberglass tanks?
Since you're asking the question on this forum, you must be inquiring about pressure vessels. Belding doesn't make pressure vessels, only atmospheric tanks. Section X of the ASME code covers FRP and composite pressure vessels.
S. Bush
sbush-
Do you know if Section X is still active? The ASME web site seems to only list the 2001 and 2004 editions, not a 2007 ed. Not sure what that means...
jt
IHS (the service my company uses) shows a July 2007 version of Section X as being the active and current version.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
Want to post an image? Look at the FAQ's in forum559
Sbush,
This is not a presssure vessel.
