Hello Everyone,
How are you all today? Hopefully you’re not caught up in any winter storms.
I’ve used this site all through college to find solutions to problems but never had an issue serious enough to post for help. Now I’m an engineer at an Army depot and a problem has come up that is worthy of a post. I searched this section of the forum before posting so I’m pretty sure this question has not been asked before.
Here’s the rub: we have just installed a gigantic horizontal boring mill here from a company called World Machinery Works (model: BP150). The issue is that the spindle stops about 22 inches off the table when the machinists need closer to 6 inches(yes, somebody goofed). Ripping out the machine and busting up the monolithic pit foundation to lower the entire machine is a major problem and the production guys say stacking another table on the original one and bolting it down is not what they want (though this seems like the easiest fix). The other option is to prop all work pieces up on stand offs they call v-blocks. But doing this would have tall work pieces far in the air and chatter/vibration would hurt milling accuracy. There seems to be no easy fix for this issue as far as anyone could see.
I brainstormed and wondered if any 90 degree spindle transmission/gearbox attachments existed that could effectively lower the cutting head without changing the table or touching the pit. Obviously doing that would have some implications, primarily the moment generated on the original axis as the spindle bits into the work piece at the new lower axis. This was the only thing I could come up with and I know it’s a pretty silly idea.
Does anyone have any better ideas I’m just not seeing here?
Any help would be appreciated.
Thanks.
Thanks.
