Brian21,
If you can't visualize what I'm describing, post your addy
and I'll send you the solution.
Try this and determine the volume of each commponent:
1. Draw a the top circle (2.00 m) and the bottom
rectangular section. For simplicity, set the 4-corner
points of the rectangle on the circumference of the
circle (rectangle length is now less than 2.00m).
2. Now looking at your drawing, there are 5-sections
(1-rectangle & 4-circular segments, 2-large/2-small).
3. Calculate the area of the rectangle, 1- large circular
segment and 1-small circular segment. Use any method
you are familiar with.
4. The volume of the hopper will be the sum of the 3
areas multiplied by the height of the hopper.
The volume calculations is based on the premise that the
volume of a sliced circular segment (slicing plane is such
that the resulting sliced cross-section is a triangle whose
2-vertices lies on the rectangular outlet and 1-vertex on
the quadrant of the circle) is half of the unsliced circular
segment.
