Hi, I have the following problem. I have a certain layup, composed of, for example, 10 plies stacked at different angles (ie a laminate). I have all properties including ply thicknesses. If I have for instance a block of this layup, is there any simple program available that will allow me to find the equivalent 3D properties of a homogeneous "resulting material"? In other words, an equivalent material with certain properties in the 3 directions that will behave like the lamiante stack. All I have found so far is laminate programs which give me the equivalent properties only in the stacking plane.
Thanks in advance,
Andrea
Thanks in advance,
Andrea
