NEPTUNE WATER
Hey guys, I am a chemical water treatment technician out of Atlanta. This is actually a question for a project Im doing for my Jiu-Jitsu academy. I'm building an airhandler with 200ft of copper tubing that goes around a 44" diameter warehouse fan. I already have the 1/4" tubing ziptied in place and hooked up a small 400gph fountain pump. The psi was not high enough to push the water through fast enough. I need help/recommendations on what kind of pump to use. HP, GPM, PSI? needs to go through roughly 200ft of 1/4" OD tubing at 1-2'/sec. Thanks!
