HOLES STANDARD 1
JeniaL
IL
trying to create holes standard for rivets but can find nothing about that over the Internet.
created a folder in catia program files and copied standard from counterbored holes folder.
any ideas on how can this be edited?
std:node name="Metric-cap-screw" xmlns:std=" <std:node name="Units">
<std:node name="Angle">
<std:strval name="angle">deg</std:strval>
</std:node>
<std:node name="Diameter">
<std:strval name="Diameter">mm</std:strval>
</std:node>
</std:node>
<std:typedef name="CounterBoredHoleValues">
<std:strval name="Name">MS20426AD3</std:strval>
<std:floatval name="MainDiameter">2.5</std:floatval>
<std:floatval name="CounterSunkDiameter">4.65</std:floatval>
<std:floatval name="CountersunkAgle">100</std:floatval>
</std:typedef>
well i'm trying to change standard in admin mode but nothing happens.
i want to define angle and diameter. when i save standard and create a hole using this standard
catia is still locked on depth and angle mode however definition in standard is angle and diameter.
 http://files.engineering.com/getfile.aspx?folder=1534780c-5450-4dea-93ee-22fb5738fb7b&file=MS20426.rar
I dont have time to test it but grab the hole standard out of the attached PDF and see if that works for you. I dug this up off the Dassault support page while checking for service packs.
Derek
Win 7
23SP5/24SP3, 3DVIA Composer 2015
 http://files.engineering.com/getfile.aspx?folder=520a5e53-eb2c-467a-8484-ac8a869d3b5e&file=More_about_User_Defined_Hole_Standards.pdf
Derek thank you so much for this attachment..works fine
