We are about to fasten down the sill plate (pressure treated wood) of a new building (concrete pad).
We plan to use hot dipped threaded rod.
We looked at installation instructions for a few epoxy anchor cements (two part).
Problem ... they all give a general note ... 1/2" and under ... hole plus 1/16 .... 5/8" or larger ... hole plus 1/8
No real tolerance.
I looked all over the web and could not find any information on how hole size affects pull out strength.
We did find a general note saying most hammer drills are designed to cut oversize (example 1/2" ... .520 to .530 dia)
I am sure this is not super critical or they would be more specific but I wanted to check with you guys ....
Is tighter better (assuming you make it large enough to get epoxy all around).
I think last time I did this (probably 10 years go ... still holding strong), I just drilled a 1/2" hole for a 1/2" bolt (I am sure it cut over size as the rods dropped in).
Should I be drilling a larger hole?
If so, why? I would think the less epoxy the better (again assuming 100% converge / contact) ... or am I wrong?
I do see lots and lots of notes and warning about how clean the holes must be so I realize this is critical.
Probably overthinking this but I want to make sure it is done right.
Thanks .... Mike
No real tolerance.
Thanks .... Mike
