jelston said:
kd2007 said:
You can countersink a thru hole using the "standard hole" iconand removing the tapping (Wildfire 2). I read somewhere that PTC is, supposedly,adding the functionality towhat they call a"straight hole".
This comment actually reminded me that i have already had a thread like this and I came to the conclusion that it was possible to countersink a clearance hole in WF 3.0. So, i looked into some more.... I would bet money on this. The countersink option is default in a threaded hole which makes no sense to me but the threaded option is grayed out. I think the threaded option was supposed to be default and the countersink option grayed out (maybe, maybe not; don't wanna argue this anymore).
I only mentioned it because I wasn't sure which version of ProE you use and I have only used Wildfire 2. So I'm not sure how previous versions of ProE handle this.
I also think the argument is due to the fact that people have different backgrounds and are arguing points from those backgrounds. After looking a little more at what dross was saying I think I understand why dross calls it countersink. From my perspective, what dross described earlier is a machining operation, he countersinks the hole so he can tap threads or add helicoils, therefore he calls the feature a countersink. However, from my background, even though you performed a countersink machining operation and from the situation described, I would not call the feature created a countersink.
