Overlords,
I have a flat head vessel with a hole, outer dia ~ 40", hole diameter ~ 14" for 120 psig (1" thick steel plate). The hole is for a bearing that supports a shaft to drive a paddle mixing assembly (There is no nozzle). I've used UG-34 to begin with but got lost when it came to evaluating the hole. Is this to be evaluated using UG-36/39/43? Or do I refer Roarks or other handbooks. I'm a bit lost.
Thank you.
Thank you.
