I recently designed a plate girder approximately 5 feet in depth with a 5/8" thick web, the span is 30'. It supports a 5" concrete floor and 2 steel columns above. The contractor wants to drill a 4" hole 4 feet from midspan and 1/3 of the way up from the bottom. Does anyone know of a method to check this condition that can be done simply with hand calculations (i.e. not FEA)? I was also interested in determining the impact of torch cutting or wet drilling the hole. Any thoughts?
