Before getting into some sort of complicated stress analysis, does anyone know if there are guidelines for holes in the center of a baseplate for circular or rectangular HSS columns?
When thinking about this the center does not seem all that important as the design is normally based on an effective cantilever distance to the bolts. However if you were to say remove then entire center of the baseplate then the moment from that cantilever distance is applied to the face of the column. I suppose though that you could add radial stiffener plates that would help distribute this moment.
Anyone done something like this before? In this case the hole is for plumbing/conduit so I imagine this has been done before. For reference, the column is 24" diameter with a substantial moment at the base on the order of 100 kip-ft.
Thanks!
EIT
Thanks!
EIT
