Hole gage distance chart
prooney
I'm looking for a chart which contains gage distances for angles and beams and the such, Can someone help a guy out? Thanks.
prooney,
AISC ASD Manual of Steel Construction should have those bolt gage charts.
If you don't have the manual, there is a spreadsheet under Go to the subject "fittings", then click "Pipe and vessel data". That spreadsheet has tabs for angle, wide flange beams, etc. that contains data like bolt gages.
Thanks doct9960, I appreciate it.
