Hole Dimension
  • Thread starter Thread starter setu_raj
  • Start date Start date
S
setu_raj
Guest
How to remove the Bracket sign from the H7 Tolerance dimension.
Setu_raj
Just
1) Double click on that dimension.
2) Then "Dimension Properties" window will appear.
3) Select "Properties" tab.
4) From here you can change tolerance properties of the dimensons
Hi Eagleeye,
My requirement is when we give a hole dimension with H7, and select the Plus-Minus Tolerance Mode then by default pro-e will show the Dimension as shown in the Image.I dont want the Bracket....
