H
hhung
Guest
Hello All,
I am having some trouble with my hole callout function on drawings.
Under the Hole Wizard selection (with tapped holes) is a category of screws added in addition to the Ansi Inch/Ansi Metric/DIN/etc. we just call "Standard", where the size is #000-120. A hole shows up on my part. but when i go to make a drawing of this part, the hole callout tool only shows up with the txt. line
<MOD-DIAM><DIM><HOLE-DEPTH>3.55
I have tried to edit the hole callout file (calloutformat.txt) and added these lines
** TAPPED HOLES **
TAP-BLIND=;\
<hw-threadsize> <hw-threadseries> <hw-threadclass> <HOLE-DEPTH>
do i have to do something else to solidworks to get the calloutformat to read new set of threads?
thanks
** TAPPED HOLES **
TAP-BLIND=;\
thanks
