From the last couple of posts, it seems that the subject has shifted to DC Injection Braking. That type of braking will tend to hold an induction motor at zero speed but not with very much torque since it takes rotor slip to magnetize the rotor. So, for DC injection braking, you will get a little drift speed as holding torque rises.
It is also true, as the poster above mentions, that the ABB ACS600 in DTC mode, can hold a load at zero speed. But you must be careful since this is only true for a couple of seconds. After that, the drive looses control of the motor torque and will release the load. Addition of an encoder will fix that but, as has been stated many times already, this is not a suitable brake technique for safety purposes. For that, trust only a spring-set mechanical brake.
