DaveVikingPE
- Aug 9, 2001
- 1,008
I've decided to add electric lampmaking to my list of hobbies.
Problem: the books on electric lampmaking rarely discuss wiring, and if they do, tying an underwriter's knot is the most detail given.
I have two lights, they're your typical, inexpensive, off-the-shelf lamps and I'd like to wire them to a single switch. The lamps are rated for a maximum of 150 W each (most likely I'll use a lower wattage bulb in each, probably a 60 W flood or spot). I live in New York, USA, the circuit in my home on which the lamps will be attached is 20A/115V AC.
So far what I've done is:
1. Cut the plug off both lamps.
2. Connected the wire from each lamp to a 20-ft length of 18/2 lamp cord. (The lamps also were 18/2). The connection is contained within a Radio Shack plastic enclosure and the wires are connected by non-soldered terminals I also bought at Rddio Shack. The hot and cold wires are spearated from each other by about .5" and they're tied down to the enclosure using plastic clips I bought at Radio Shack. (I'm not advertising for Radio Shack, but...) Prior to attaching any switching to the 20-ft cord, I tested the connection by attaching a plug (that I bought at Home Depot) to its end and plugging it in. The lamps functioned normally and I didn't detect any heat (a concern?) coming from the plastic enclosure after five minutes.
What I am exploring doing is adding an on/off switch to the 20-ft cord. I want to add a rocker switch (with enclosure) to the cord, the purpose of which is that I want to fix the switch to the side of a bookcase, rather than having the cord hang. Radio Shack sells a maintained rocker switch that's rated at 6A/125V AC. In order to attach this switch, I would cut the 20-ft cord at the appropriate length and wire it to the switch, hot-hot, cold-cold. I would then place the switch in another plastic enclosure that would be fixed to the bookcase.
Thoughts/Questions/Suggestions?
Thanks very much in advance!
