I am trying to hob a "Grob standard" spline into a part.
It is a very obscure type of straight sided tooth form that isn't used very often. We have a cutter that successfully formed the spline on a mostly manual machine several years ago. We are now trying to make it on a newer and more sophisticated machine.
Many of the typical involute variables that this machine needs to program don't exactly exist in these grob standards. (Diametrical pitch and pressure angle for example. I've talked with the manufacturer of the cutter and they gave me numbers to use, but of course wouldn't tell me where those numbers come from.
For whatever reason, I can not seem to create a straight sided tooth...I always get a slight involute or my teeth aren't parallel like they are supposed to be. The critical measurements are the chord thickness across two teeth..and the root diameter, and I can never manage to get both.
I would really appreciate any ideas anyone has on how I can accomplish this. I expect I'm missing something very simple.
FYI...here is a site for grob information...
We're making the 2250-24-2 type
Thank you
Thank you
