D
dakeb1
Guest
WF3. I have a drawing with a number of sheets and views that I want to enable HLR for quilts. I have selected View/Properties on some of them and successfully hidden the quilts.
However, there is one projection view containing a local section that the option is greyed out, and it is not removing quilt hidden lines.
It's parent view has HLR removal checked, and does not show hidden lines.
There is also a detail view related to it if that makes any difference.
The same parent view has another projection view that allows me to check the HLR box.
I implemented the hlr_for_quilts config.pro option but it doesn't seem to work on views that already exist in a drawing.
I tried changing the view to a "general" view, and still the option is greyed out.
Is it something to do with the local section or detail view? If so, why? How do I fix it?
David
David
