btcoutermash
Industrial
Does anybody have any good articles where they have compared history based -vs- Non history based CAD software??? Primarily I was lloking for productivity benchmarks. Any help would be great. Thanx.
Brad
Brad
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
For 3D solid design I'd give Vellum a 9 and SW a 5.
For 3D solid drawing (drawing things that are already designed) I'd give Vellum a 8.5 and SW a 7.
For detail drawings I'd give Vellum a 6 and SW a 8.
For file management I'd give Vellum a 8 and SW a 4 (sorry assemblies with hundreds of part files still drive me insane, much prefer 1 file for 1 assembly).
For finding pre-drawn parts on the web I'd give SW a 10 and Vellum a 1 (it's fringe software, no where near the # of users).
For modifying and using imported parts (something I do quite often) I'd give Vellum a 10 and SW a 2. Vellum can easily use 3D wireframe data to create models, and can work with dumb solids w/ almost zero problems; neither is true for SW.
Even though you gave SW a higher score, im still surprised, because SW draiwng usually get a low score, because they are not AutoCAD drawing, and most user frown at SW drawings. However I think they do a great job and always had since I started using them in 96 and at the point SW was limited versus where it is at now.For detail drawings I'd give Vellum a 6 and SW a 8.
but it will take a bit of extra work to create the rounded end.
Both programs are capable of this, but in SW's case, the software itself inhibits rather then helps the design process.
Being limited to drawing on fixed point planes makes it very time consuming and slow to attempt to transfer points from parts A & B to connecting bracket C you are attempting to design.
They have not been the best, but after years of working with them the are not that bad. You have to just understand how they work. SW06 is going to fix a lot of the 3D sketch limitations though.3D sketching capabilities in SW are pathetic.
Here I'd give Vellum a 10 and SW a 1, there is no comparison. SW has other features that help later in the design process, thus I upped it's score to a 5 and lowered Vellum's to a 9. But, for whipping up a quick sketch to work through several different design ideas SW sucks.
One thing I've found as I gain more design experience is that designs get more complicated because instead of struggling to think of something that'll work I have to quickly decide on one of the 6 different ideas that pop into my head. It's quite easy to do this in vellum by simply positioning known parts in approximate locations and sketching ideas around them. Using a combination of simple solid shapes and 3D wireframe.
With SW it's easier to sketch on paper (which I'm not that good at).<G> An article I recently cut out of Design News (I think) says it better then I can: "CAD systems often constrain engineers rather then liberate them to do their best and most creative designs....Most CAD tools available are not focused on creativity...The tools are meant for documenting not creatively developing a design. I find SW extremely constricting when designing things. SW is very inferior when it comes to ease of manuvering and manipulating things in a 3D environment
I'd disagree that market share means a product is 'better'. For many years Apples OS was vastly superior to Windows (not much difference anymore). Autocad was lousy software when I learned it, vastly inferior to CadKey which I also used, but it still dominated the CAD world for years (only meant it was more well known and marketed better, not that it was better). Vellum made the mistake of being strictly Mac software, up until about 2000 which greatly limited their market.
I will say that I can, eventually, draw most anything I wish to with SW. But, in many instances it's not nearly as straightforward as I'm used to, takes many more steps, and I spend the majority of my time not thinking about the design and how to improve it, but how to use the software (hopefully that'll improve).
