jorton
- Sep 20, 2005
- 108
I'm working on a 100+ year old building that was originally built as an ice house. It consists of 7 stories of heavy reinforced concrete frame (very heavy – presumably to support ice). The façade is 2-wythe brick that goes all the way up. There is a large offset (several inches) between the concrete frame and the brick for cork and fart-rock insulation. The brick is tied back to the frame at large spacings (one to two per story) with what appears to be a steel pipe that is embedded at both ends. The ties are roughly spaced 16'-20' horizontally (at the columns) and 6'-10' vertically. I'm trying to understand the makeup of the brick façade and tie system. The robust tie makes me suspect that it is attached to some sort of internal reinforcing in the brick. Does anyone have any details, information, or experience with this sort of system that they will share? Thanks.
