The General Contractor wants to fasten OSB roof sheathing to Steel Wide Flanges or HSS with HILTI PAF pins rather than the specified TEK-5 screws.
Genreally, HILTI pins are for fastening light gage steel to the thicker base material, such that, the fastened material is thin, or of gage thickness maximum, such that the PAF pin is "essentially" already engaged in intimate contact with the base material.
FYI, it is NOT recommended to fasten thicker material, i.e. 1/4"+ steel thickness to a base material, since that thickness of steel to be "fastened" is too thick, such that it would slow down, or hinder the PAF from proper or acceptable penetration into the base material. 1/8" or 12 gage may even be too thick to fasten to a base, as is implied by the HILTI Direct Fastening Technical Guide.
So what about OSB or plywood?
Granted OSB is 5/8" (in this case) BUT... it's OSB! OSB would NOT... SHOULD not hinder a PAF so much as to slow it down from penetrating the base material. But, the pin point WOULD be that thickness away from the base!
Would YOU allow it?
Thoughts?
Would YOU allow it?
Thoughts?
