SlideRuleEra
- Jun 2, 2003
- 5,527
I would like for you folks to help educate me on some of the questions that routine come up in the foundation, geotechnical, etc. forums. I have worked virtually all of my career in areas (coastal South Carolina) where the water table is normally at, or just below the ground surface. To us (local Engineers & once-upon-a-time as a heavy construction Contractor) - this is no big deal. The foundations (spread footings, piling, drilled pier, etc. "work" properly when located above, below and at the water table. Constructing them (controlling groundwater) takes a certain amount of understanding, but is not "rocket science". This is just every day business - not a problem.
Yet I routinely see questions where the member "freaks out" because they have encountered ground water in an excavation - and don't know what to do about it (either for design & construction).
Do soils / ground water in other parts of the world cause more problems than I am aware of? Or are high water tables an unusual situation that seems "normal" to me?
![[idea] [idea] [idea]](/data/assets/smilies/idea.gif)
